Ir para o conteúdo principal
Dell Inspiron 13-7370 Fan Replacement
O que você precisa
  1. Dell Inspiron 13-7370 Fan Replacement, Fan: passo 1, imagem 1 %32 Dell Inspiron 13-7370 Fan Replacement, Fan: passo 1, imagem 2 %32 Dell Inspiron 13-7370 Fan Replacement, Fan: passo 1, imagem 3 %32
    • Make sure the laptop is turned off and not connected to a charging cable.
    • Using a Phillips #0 screwdriver, remove the ten (10) 2.5 mm screws fastening the bottom cover.
  2. Dell Inspiron 13-7370 Fan Replacement: passo 2, imagem 1 %32 Dell Inspiron 13-7370 Fan Replacement: passo 2, imagem 2 %32
    • Starting around the edges of the laptop, lift and remove the back cover. Apply pressure upwards, until you hear a popping noise.
    • Moving clockwise around the laptop, continue to apply pressure upwards, using your fingers or a plastic pick, until the bottom cover pops out of its locks.
  3. Dell Inspiron 13-7370 Fan Replacement: passo 3, imagem 1 %32 Dell Inspiron 13-7370 Fan Replacement: passo 3, imagem 2 %32
    • Using the Phillips #0 screwdriver, remove the four 2 mm screws.
    • Carefully disconnect the battery from the motherboard.
  4. Dell Inspiron 13-7370 Fan Replacement: passo 4, imagem 1 %32 Dell Inspiron 13-7370 Fan Replacement: passo 4, imagem 2 %32
    • Using the Phillips #0 screwdriver, remove the two 2 mm screws holding the fan in place.
  5. Dell Inspiron 13-7370 Fan Replacement: passo 5, imagem 1 %32 Dell Inspiron 13-7370 Fan Replacement: passo 5, imagem 2 %32 Dell Inspiron 13-7370 Fan Replacement: passo 5, imagem 3 %32
    • Lifting the fan, disconnect it from the laptop by grasping the connector (circled in red), and pulling out horizontally.
    • Do NOT pull the connecter upwards, as this may damage the socket you are pulling it out of.
  6. Dell Inspiron 13-7370 Fan Replacement: passo 6, imagem 1 %32
    • Remove the fan from the device.
Conclusão
Uma outra pessoa concluiu este guia.
Zayed Azam
Membro desde: 05/16/21
133 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 11
Duração total: 753
