Ir para o conteúdo principal
Dell Inspiron 13-7359 WLAN Adaptor Replacement
O que você precisa
  1. Dell Inspiron 13-7359 WLAN Adaptor Replacement, Battery: passo 1, imagem 1 %32
    • First flip over the laptop to expose the back panel
    • Use a Phillips #0 screwdriver to unscrew all ten 7mm Phillips head screws holding the back panel in place.
  2. Dell Inspiron 13-7359 WLAN Adaptor Replacement: passo 2, imagem 1 %32
    • With a plastic spudger, carefully remove the back panel by prying each corner off individually
    • Slowly pick up the panel and set it aside
  3. Dell Inspiron 13-7359 WLAN Adaptor Replacement: passo 3, imagem 1 %32 Dell Inspiron 13-7359 WLAN Adaptor Replacement: passo 3, imagem 2 %32 Dell Inspiron 13-7359 WLAN Adaptor Replacement: passo 3, imagem 3 %32
    • The battery will be the largest black component in the device located near the bottom edge. Using a Phillips #0 screwdriver, unscrew the two 3mm Phillips head screws holding in the battery.
  4. Dell Inspiron 13-7359 WLAN Adaptor Replacement: passo 4, imagem 1 %32 Dell Inspiron 13-7359 WLAN Adaptor Replacement: passo 4, imagem 2 %32 Dell Inspiron 13-7359 WLAN Adaptor Replacement: passo 4, imagem 3 %32
    • To remove the old battery, slightly lift the bottom edge of the battery with your hands
    • Now slowly pull the battery towards you to fully detach the battery
  5. Dell Inspiron 13-7359 WLAN Adaptor Replacement, WLAN Adaptor: passo 5, imagem 1 %32
    • Unhook both of the wires attached to the WLAN adaptor.
  6. Dell Inspiron 13-7359 WLAN Adaptor Replacement: passo 6, imagem 1 %32
    • Remove the 3.9mm Phillips screw using Phillips #0 screwdriver.
    • Once the screw is removed, one end of the WLAN adaptor will raise up.
  7. Dell Inspiron 13-7359 WLAN Adaptor Replacement: passo 7, imagem 1 %32
    • Gently remove the WLAN adaptor.
Conclusão
Bo Yi Lim
Membro desde: 04/02/19
205 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S3-G4, Harley Spring 2019 Membro de IUPUI, Team S3-G4, Harley Spring 2019
IUPUI-HARLEY-S19S3G4
Membros da 3
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 166
