Pular para o conteúdo principal
Introdução
This guide will give you step by step instructions to removing your Dell Inspiron 13-7359 laptop speaker. You will need a phillips head #0 screwdriver and a plastic spudger.
  1. First flip over the laptop to expose the back panel
    • First flip over the laptop to expose the back panel
    • Use a Phillips #0 screwdriver to unscrew all ten 7mm Phillips head screws holding the back panel in place.
  2. With a plastic spudger, carefully remove the back panel by prying each corner off individually
    • With a plastic spudger, carefully remove the back panel by prying each corner off individually
    • Slowly pick up the panel and set it aside
  3. The battery will be the largest black component in the device located near the bottom edge. Using a Phillips #0 screwdriver, unscrew the two 3mm Phillips head screws holding in the battery. The battery will be the largest black component in the device located near the bottom edge. Using a Phillips #0 screwdriver, unscrew the two 3mm Phillips head screws holding in the battery. The battery will be the largest black component in the device located near the bottom edge. Using a Phillips #0 screwdriver, unscrew the two 3mm Phillips head screws holding in the battery.
    • The battery will be the largest black component in the device located near the bottom edge. Using a Phillips #0 screwdriver, unscrew the two 3mm Phillips head screws holding in the battery.
  4. PC Laptop Batteries
    An easy fix for a big power boost.
    Comprar agora
    PC Laptop Batteries
    Comprar agora
  5. To remove the old battery, slightly lift the bottom edge of the battery with your hands Now slowly pull the battery towards you to fully detach the battery Now slowly pull the battery towards you to fully detach the battery
    • To remove the old battery, slightly lift the bottom edge of the battery with your hands
    • Now slowly pull the battery towards you to fully detach the battery
  6. Following the removal of the Battery, remove the left speaker. As you lift the left speaker, carefully lift the wire that connects the left and right speakers.
    • Following the removal of the Battery, remove the left speaker.
    • As you lift the left speaker, carefully lift the wire that connects the left and right speakers.
  7. Disconnect the small wires attached to the top of the right side speaker as marked in the photo. Disconnect the small wires attached to the top of the right side speaker as marked in the photo.
    • Disconnect the small wires attached to the top of the right side speaker as marked in the photo.
  8. Use the plastic spudger to safely and easily detach the right speaker from the device. Lift the right speaker out to complete the removal.
    • Use the plastic spudger to safely and easily detach the right speaker from the device.
    • Lift the right speaker out to complete the removal.
Conclusão
Uma outra pessoa concluiu este guia.
Katie Ragsdale
Membro desde: 30-01-2018
145 reputação
Autoria de 1 guia
Equipe
Baylor, Team S1-G6, Johnson Spring 2018 Membro de Baylor, Team S1-G6, Johnson Spring 2018
BU-JOHNSON-S18S1G6
3 Membros
5 Guias de autoria
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Todo: 130
