Ir para o conteúdo principal
Dell Inspiron 13-7359 Hard Drive Replacement
O que você precisa
  1. Dell Inspiron 13-7359 Hard Drive Replacement, Back Cover: passo 1, imagem 1 %32
    • Flip your device over so the back cover is facing you.
    • Using a Phillips #0 Screwdriver, remove the ten 7mm screws holding the back cover in place.
  2. Dell Inspiron 13-7359 Hard Drive Replacement: passo 2, imagem 1 %32
    • Insert a plastic opening and run it along the edge of the back cover. Do this until the entire back cover can be removed.
  3. Dell Inspiron 13-7359 Hard Drive Replacement, Hard Drive: passo 3, imagem 1 %32
    • Unscrew and remove the 2 of the 3mm Phillips head screws holding the hard drive in place.
  4. Dell Inspiron 13-7359 Hard Drive Replacement: passo 4, imagem 1 %32 Dell Inspiron 13-7359 Hard Drive Replacement: passo 4, imagem 2 %32
    • Lift and hold the hard drive in your left hand.
    • Use your right hand to grab hold of the black wire connector attached on the right of the hard drive.
    • Carefully pull the connector away from the hard drive to completely disconnect from the laptop.
Conclusão
6 outras pessoas executaram este guia.
Valentin Medina
Membro desde: 01/30/18
703 Reputação
Autoria de 3 guias
Equipe
Baylor, Team S1-G6, Johnson Spring 2018 Membro de Baylor, Team S1-G6, Johnson Spring 2018
BU-JOHNSON-S18S1G6
3 Membros
Autoria de 5 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 22
Ao todo: 2,061
