Ir para o conteúdo principal
Dell Inspiron 13-7359 Cooling Fan Replacement
O que você precisa
  1. Dell Inspiron 13-7359 Cooling Fan Replacement, Back Cover: passo 1, imagem 1 %32
    • Flip your device over so the back cover is facing you.
    • Using a Phillips #0 Screwdriver, remove the ten 7mm screws holding the back cover in place.
  2. Dell Inspiron 13-7359 Cooling Fan Replacement: passo 2, imagem 1 %32
    • Insert a plastic opening and run it along the edge of the back cover. Do this until the entire back cover can be removed.
  3. Dell Inspiron 13-7359 Cooling Fan Replacement, Cooling Fan: passo 3, imagem 1 %32 Dell Inspiron 13-7359 Cooling Fan Replacement, Cooling Fan: passo 3, imagem 2 %32
    • Unscrew and remove the 2 of the 7mm Phillips head screws holding the cooling fan in place.
  4. Dell Inspiron 13-7359 Cooling Fan Replacement: passo 4, imagem 1 %32
    • Hold the cooling fan with one hand.
    • With the other hand, grab hold of the part of the copper heat sink that is attached to the cooling fan.
    • Carefully pull the cooling fan away from the attached part so that it becomes fully disconnected.
Conclusão
Valentin Medina
Membro desde: 01/30/18
697 Reputação
Autoria de 3 guias
Equipe
Baylor, Team S1-G6, Johnson Spring 2018 Membro de Baylor, Team S1-G6, Johnson Spring 2018
BU-JOHNSON-S18S1G6
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 11
Duração total: 622
