Ir para o conteúdo principal
Dell Inspiron 13-7359 Battery Replacement
O que você precisa
  1. Dell Inspiron 13-7359 Battery Replacement, Battery: passo 1, imagem 1 %32
    • First flip over the laptop to expose the back panel
    • Use a Phillips #0 screwdriver to unscrew all ten 7mm Phillips head screws holding the back panel in place.
  2. Dell Inspiron 13-7359 Battery Replacement: passo 2, imagem 1 %32
    • With a plastic spudger, carefully remove the back panel by prying each corner off individually
    • Slowly pick up the panel and set it aside
  3. Dell Inspiron 13-7359 Battery Replacement: passo 3, imagem 1 %32 Dell Inspiron 13-7359 Battery Replacement: passo 3, imagem 2 %32 Dell Inspiron 13-7359 Battery Replacement: passo 3, imagem 3 %32
    • The battery will be the largest black component in the device located near the bottom edge. Using a Phillips #0 screwdriver, unscrew the two 3mm Phillips head screws holding in the battery.
  4. Dell Inspiron 13-7359 Battery Replacement: passo 4, imagem 1 %32 Dell Inspiron 13-7359 Battery Replacement: passo 4, imagem 2 %32 Dell Inspiron 13-7359 Battery Replacement: passo 4, imagem 3 %32
    • To remove the old battery, slightly lift the bottom edge of the battery with your hands
    • Now slowly pull the battery towards you to fully detach the battery
Conclusão
4 outras pessoas executaram este guia.
Valentin Medina
Membro desde: 01/30/18
703 Reputação
Autoria de 3 guias
Equipe
Baylor, Team S1-G6, Johnson Spring 2018 Membro de Baylor, Team S1-G6, Johnson Spring 2018
BU-JOHNSON-S18S1G6
3 Membros
Autoria de 5 guias
1Comentário do guia
thanks for this, my daughter’s laptop now needs a new battery and while I assumed it would be easy, it’s good to get a preview.
Paul M - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 27
Ao todo: 1,675
