Introdução
A misfunctioning or broken Keyboard and/or Touchpad is actually an inexpensive fix that may save you from having to throw away an otherwise working device.
Please review attached safety information before beginning repair.
Safety
Please review safety information found here before working on your device.
O que você precisa
Remove the 10 - M2.5 x 8mm screws located on the bottom of the device.
Detach and remove the Bottom Base Cover using an opening tool to pry it off.
5 outras pessoas executaram este guia.
