Ir para o conteúdo principal
Dell Inspiron 13-7353 Palmrest Keyboard Replacement
O que você precisa
  1. Dell Inspiron 13-7353 Palmrest Keyboard Replacement, Palmrest Keyboard and Touchpad: passo 1, imagem 1 %32 Dell Inspiron 13-7353 Palmrest Keyboard Replacement, Palmrest Keyboard and Touchpad: passo 1, imagem 2 %32 Dell Inspiron 13-7353 Palmrest Keyboard Replacement, Palmrest Keyboard and Touchpad: passo 1, imagem 3 %32
    • Remove the 10 - M2.5 x 8mm screws located on the bottom of the device.
    • Detach and remove the Bottom Base Cover using an opening tool to pry it off.
  2. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: passo 2, imagem 1 %32 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: passo 2, imagem 2 %32 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: passo 2, imagem 3 %32
    • Unplug and gently pull the hard drive cable to loosen it.
    • Remove the 2 - M2 x 3mm screws.
    • Remove the Battery.
  3. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: passo 3, imagem 1 %32 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: passo 3, imagem 2 %32 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: passo 3, imagem 3 %32
    • Remove the 2 - M2 x 3mm hard drive screws.
    • Remove the Hard Drive.
  4. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: passo 4, imagem 1 %32 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: passo 4, imagem 2 %32
    • Unplug the speaker cable.
    • Remove the Speakers.
  5. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: passo 5, imagem 1 %32 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: passo 5, imagem 2 %32
    • Unplug the fan cable.
    • Unplug and remove the daughter board cable.
  6. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: passo 6, imagem 1 %32 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: passo 6, imagem 2 %32 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: passo 6, imagem 3 %32
    • Unplug the antenna cables.
    • Unplug the power button cable.
  7. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: passo 7, imagem 1 %32 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: passo 7, imagem 2 %32
    • Remove the 1 - M2 x 3mm screw.
    • Remove the USB / SD Card Circuit Board.
  8. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: passo 8, imagem 1 %32 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: passo 8, imagem 2 %32 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: passo 8, imagem 3 %32
    • Remove the 1 - M2 x 3mm and 1 - M2 x 2mm Wafer screw.
    • Remove the Cooling Fan.
  9. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: passo 9, imagem 1 %32 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: passo 9, imagem 2 %32 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: passo 9, imagem 3 %32
    • Loosen the screws.
    • Remove the Heatsink.
  10. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: passo 10, imagem 1 %32 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: passo 10, imagem 2 %32
    • Remove the 2 - M2 x 3mm bracket screws.
    • Remove the LCD cable bracket.
  11. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: passo 11, imagem 1 %32 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: passo 11, imagem 2 %32
    • Unplug the LCD cable.
    • Unplug the touchscreen cable.
  12. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: passo 12, imagem 1 %32 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: passo 12, imagem 2 %32 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: passo 12, imagem 3 %32
    • Open the screen.
    • Loosen the LCD cable and peel it off of the base (highlighted with arrow).
    • Remove the 3 - M2.5 x 8mm hinge screws.
  13. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: passo 13, imagem 1 %32 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: passo 13, imagem 2 %32
    • Remove the screen assembly.
    • You may need to pull the hinges up.
  14. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: passo 14, imagem 1 %32 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: passo 14, imagem 2 %32 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: passo 14, imagem 3 %32
    • Unplug the cable.
    • Remove the DC Jack.
  15. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: passo 15, imagem 1 %32 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: passo 15, imagem 2 %32
    • Loosen the keyboard cable tape.
    • Loosen the keyboard cable latches.
    • Unplug the keyboard cable.
  16. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: passo 16, imagem 1 %32
    • Unplug the keyboard backlight cable.
    • Unplug the touchpad cable.
  17. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: passo 17, imagem 1 %32 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: passo 17, imagem 2 %32
    • Remove the 1 - M2 x 2mm Wafer screw.
    • Remove the Motherboard.
    • The piece remaining is the Palmrest Keyboard.
  18. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: passo 18, imagem 1 %32
    • You can further disassemble by removing the touchpad.
  19. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: passo 19, imagem 1 %32 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: passo 19, imagem 2 %32 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: passo 19, imagem 3 %32
    • Unscrew the 4 - 2x2mm wafer screws.
    • Peel back any tape holding the back plate on.
    • Lift and remove back plate.
  20. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: passo 20, imagem 1 %32 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: passo 20, imagem 2 %32 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: passo 20, imagem 3 %32
    • Peel back under-button tape.
    • Remove touchpad.
    • You have now stripped the keyboard! It is ready to be replaced.
Conclusão
5 outras pessoas executaram este guia.
Documentos anexados
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 12
Últimos 30 dias: 21
Ao todo: 7,295
