Ir para o conteúdo principal
Dell Inspiron 13-7352 Hard Drive Replacement
O que você precisa
  1. Dell Inspiron 13-7352 Hard Drive Replacement, Battery: passo 1, imagem 1 %32 Dell Inspiron 13-7352 Hard Drive Replacement, Battery: passo 1, imagem 2 %32 Dell Inspiron 13-7352 Hard Drive Replacement, Battery: passo 1, imagem 3 %32
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use a Phillips screwdriver to remove the ten 7.5mm screws that securing the back panel.
    • Use the plastic opening tool to pry up and loosen the back panel.
    • Remove the back panel.
  2. Dell Inspiron 13-7352 Hard Drive Replacement: passo 2, imagem 1 %32 Dell Inspiron 13-7352 Hard Drive Replacement: passo 2, imagem 2 %32
    • Use a Phillips screwdriver to remove the two 3 mm screws securing the battery.
    • Unclip the hard drive wire from the battery.
  3. Dell Inspiron 13-7352 Hard Drive Replacement: passo 3, imagem 1 %32
    • Gently remove the battery from the rest of the device.
  4. Dell Inspiron 13-7352 Hard Drive Replacement, Hard Drive: passo 4, imagem 1 %32 Dell Inspiron 13-7352 Hard Drive Replacement, Hard Drive: passo 4, imagem 2 %32
    • Locate the Hard Drive.
    • Remove the two 3mm screws from Hard Drive with the Phillips #0 head.
    • Disconnect the wire attached to the system board by lifting up the tape.
    • Remove the tape tab from the Hard Drive by lifting the tape up and off of the Hard Drive unit.
  5. Dell Inspiron 13-7352 Hard Drive Replacement: passo 5, imagem 1 %32 Dell Inspiron 13-7352 Hard Drive Replacement: passo 5, imagem 2 %32 Dell Inspiron 13-7352 Hard Drive Replacement: passo 5, imagem 3 %32
    • Once disconnected from the tape and the connector is free, lift the Hard Drive unit from the rest of the device by grasping each side with thumb and index or middle finger.
Conclusão
5 outras pessoas executaram este guia.
Chase Sparkman
Membro desde: 09/30/15
506 Reputação
Autoria de 2 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 12
Duração total: 9,275
