Introdução
The cooling fan keeps the devices internal components from overheating during operation. It is located in the rear center of the base next to the exhaust vent.
O que você precisa
Use a Phillips screwdriver to remove the ten 7.5mm screws that securing the back panel.
Use the plastic opening tool to pry up and loosen the back panel.
Remove the back panel.
Quase terminado!
Conclusão
