Ir para o conteúdo principal
Dell Inspiron 13-7347 Touchpad Replacement
O que você precisa
  1. Dell Inspiron 13-7347 Touchpad Replacement, Battery: passo 1, imagem 1 %32 Dell Inspiron 13-7347 Touchpad Replacement, Battery: passo 1, imagem 2 %32 Dell Inspiron 13-7347 Touchpad Replacement, Battery: passo 1, imagem 3 %32
    • Flip the device over, so that the back is facing up.
    • Remove the ten, 7 mm, Phillips #1 screws on the back of your Dell Inspiron 13-7347.
    • Use the suction cup to lift off the back case.
  2. Dell Inspiron 13-7347 Touchpad Replacement: passo 2, imagem 1 %32 Dell Inspiron 13-7347 Touchpad Replacement: passo 2, imagem 2 %32 Dell Inspiron 13-7347 Touchpad Replacement: passo 2, imagem 3 %32
    • Remove the three 4 mm JIS #00 screws that secure the battery to the device.
  3. Dell Inspiron 13-7347 Touchpad Replacement: passo 3, imagem 1 %32 Dell Inspiron 13-7347 Touchpad Replacement: passo 3, imagem 2 %32 Dell Inspiron 13-7347 Touchpad Replacement: passo 3, imagem 3 %32
    • Unplug the flat connector that is connected to the battery.
  4. Dell Inspiron 13-7347 Touchpad Replacement: passo 4, imagem 1 %32 Dell Inspiron 13-7347 Touchpad Replacement: passo 4, imagem 2 %32 Dell Inspiron 13-7347 Touchpad Replacement: passo 4, imagem 3 %32
    • Lift the battery steadily from the device.
    • Tilt the battery upward while removing.
  5. Dell Inspiron 13-7347 Touchpad Replacement, Touchpad: passo 5, imagem 1 %32 Dell Inspiron 13-7347 Touchpad Replacement, Touchpad: passo 5, imagem 2 %32
    • Unplug the sliding connector.
    • The cord is extremely fragile.
  6. Dell Inspiron 13-7347 Touchpad Replacement: passo 6, imagem 1 %32 Dell Inspiron 13-7347 Touchpad Replacement: passo 6, imagem 2 %32 Dell Inspiron 13-7347 Touchpad Replacement: passo 6, imagem 3 %32
    • Flip the cord upward.
  7. Dell Inspiron 13-7347 Touchpad Replacement: passo 7, imagem 1 %32 Dell Inspiron 13-7347 Touchpad Replacement: passo 7, imagem 2 %32
    • Remove the four 2.5 mm JIS #00 screws.
  8. Dell Inspiron 13-7347 Touchpad Replacement: passo 8, imagem 1 %32 Dell Inspiron 13-7347 Touchpad Replacement: passo 8, imagem 2 %32 Dell Inspiron 13-7347 Touchpad Replacement: passo 8, imagem 3 %32
    • Flip the metal plate upward.
    • Take out the metal plate completely.
  9. Dell Inspiron 13-7347 Touchpad Replacement: passo 9, imagem 1 %32 Dell Inspiron 13-7347 Touchpad Replacement: passo 9, imagem 2 %32 Dell Inspiron 13-7347 Touchpad Replacement: passo 9, imagem 3 %32
    • Remove the touchpad by lifting up the handle.
Conclusão
lee120496
Membro desde: 02/05/19
643 Reputação
Autoria de 4 guias
Equipe
UC Davis, Team S20-G8, Lore Winter 2019 Membro de UC Davis, Team S20-G8, Lore Winter 2019
UCD-LORE-W19S20G8
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 480
