Ir para o conteúdo principal
Dell Inspiron 13-5368 Screen Display Replacement
O que você precisa
  1. Dell Inspiron 13-5368 Screen Display Replacement, Battery: passo 1, imagem 1 %32 Dell Inspiron 13-5368 Screen Display Replacement, Battery: passo 1, imagem 2 %32
    • Remove the nine 6mm Phillips #0 screws that secure the back cover of the laptop.
  2. Dell Inspiron 13-5368 Screen Display Replacement: passo 2, imagem 1 %32 Dell Inspiron 13-5368 Screen Display Replacement: passo 2, imagem 2 %32
    • Use a spudger to pry up and remove the back cover.
  3. Dell Inspiron 13-5368 Screen Display Replacement: passo 3, imagem 1 %32
    • Remove the four 3mm Phillips #0 screws at the corners of the battery that secure it to the laptop.
  4. Dell Inspiron 13-5368 Screen Display Replacement: passo 4, imagem 1 %32
    • Pull the battery cable's black tab towards the battery to disconnect it from the motherboard.
    • Pull the tab parallel to the motherboard, not straight up.
  5. Dell Inspiron 13-5368 Screen Display Replacement: passo 5, imagem 1 %32 Dell Inspiron 13-5368 Screen Display Replacement: passo 5, imagem 2 %32
    • Remove the battery.
  6. Dell Inspiron 13-5368 Screen Display Replacement, Screen Display: passo 6, imagem 1 %32 Dell Inspiron 13-5368 Screen Display Replacement, Screen Display: passo 6, imagem 2 %32 Dell Inspiron 13-5368 Screen Display Replacement, Screen Display: passo 6, imagem 3 %32
    • Unscrew the 2mm screw that holds the WLAN card. Then carefully remove the WLAN card from the motherboard.
  7. Dell Inspiron 13-5368 Screen Display Replacement: passo 7, imagem 1 %32
    • Detach the black and white antenna cables from the WLAN card.
  8. Dell Inspiron 13-5368 Screen Display Replacement: passo 8, imagem 1 %32
    • Unplug the two display cables.
  9. Dell Inspiron 13-5368 Screen Display Replacement: passo 9, imagem 1 %32
    • Unscrew the screws that are securing the laptop's hinges.
  10. Dell Inspiron 13-5368 Screen Display Replacement: passo 10, imagem 1 %32
    • Detach the display from the base.
Conclusão
Matt Sugrim
Membro desde: 09/27/17
1.042 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team S14-G6, Boczar Fall 2017 Membro de USF Tampa, Team S14-G6, Boczar Fall 2017
USFT-BOCZAR-F17S14G6
Membros da 4
Autoria de 13 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 19
Duração total: 2,184
