Ir para o conteúdo principal
Dell Inspiron 13 N3010 Display Assembly Replacement
O que você precisa
  1. Dell Inspiron 13 N3010 Display Assembly Replacement, Remove the Screws: passo 1, imagem 1 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Remove the two screws on the bottom of the computer that secure the display assembly to the computer base.
  2. Dell Inspiron 13 N3010 Display Assembly Replacement, Disconnecting the Display Cable: passo 2, imagem 1 %32
    • Open the display as far as possible.
    • Pull the pull-tab to disconnect the display cable from the connector on the system board.
  3. Dell Inspiron 13 N3010 Display Assembly Replacement, Remove the Display Cable: passo 3, imagem 1 %32
    • Remove the display cable grounding screw.
    • NOTE: Open the display at a 90-degree angle to the plane.
  4. Dell Inspiron 13 N3010 Display Assembly Replacement, Remove the Screws: passo 4, imagem 1 %32
    • In sequential order (indicated on the display hinge), remove the four screws that secure the display assembly to the computer base.
  5. Dell Inspiron 13 N3010 Display Assembly Replacement, Lifting the Display Assembly: passo 5, imagem 1 %32
    • Lift the display assembly off the computer.
  6. Dell Inspiron 13 N3010 Display Assembly Replacement, Placing the Display Assembly: passo 6, imagem 1 %32
    • Place the NEW display assembly in position.
  7. Dell Inspiron 13 N3010 Display Assembly Replacement, Replace the Screws: passo 7, imagem 1 %32
    • In sequential order (indicated on the display hinge), replace the four screws that secure the display assembly to the computer base.
  8. Dell Inspiron 13 N3010 Display Assembly Replacement, Connecting the Display Cable: passo 8, imagem 1 %32
    • Connect the display cable to the connector on the system board.
  9. Dell Inspiron 13 N3010 Display Assembly Replacement, Replace the Display Cable: passo 9, imagem 1 %32
    • Replace the display cable grounding screw.
  10. Dell Inspiron 13 N3010 Display Assembly Replacement, Replace the Screws: passo 10, imagem 1 %32
    • Turn the computer over and replace the two screws that secure the display assembly to the computer base.
Conclusão
Uma outra pessoa concluiu este guia.
Terrence15
Membro desde: 12/18/17
79.243 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.989 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 347
