Introdução
In this guide, we will show you how to remove and replace the Display Assembly.
O que você precisa
Remove the two screws on the bottom of the computer that secure the display assembly to the computer base.
Open the display as far as possible.
Pull the pull-tab to disconnect the display cable from the connector on the system board.
In sequential order (indicated on the display hinge), remove the four screws that secure the display assembly to the computer base.
In sequential order (indicated on the display hinge), replace the four screws that secure the display assembly to the computer base.
Connect the display cable to the connector on the system board.
Turn the computer over and replace the two screws that secure the display assembly to the computer base.
Uma outra pessoa concluiu este guia.
