Ir para o conteúdo principal
Dell Inspiron 13 N3010 Battery Replacement
O que você precisa
  1. Dell Inspiron 13 N3010 Battery Replacement, Sliding the Battery Lock Latch: passo 1, imagem 1 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer)
    • Turn the computer over.
    • Slide the battery lock latch to the unlock position.
  2. Dell Inspiron 13 N3010 Battery Replacement, Sliding the Battery Release Latch: passo 2, imagem 1 %32
    • Slide the battery release latch to the side.
  3. Dell Inspiron 13 N3010 Battery Replacement, Lifting the Battery: passo 3, imagem 1 %32
    • Slide and lift the battery out of the battery bay.
  4. Dell Inspiron 13 N3010 Battery Replacement, Sliding the Battery: passo 4, imagem 1 %32
    • Slide the NEW battery into the battery bay, until it clicks into place.
  5. Dell Inspiron 13 N3010 Battery Replacement, Sliding the Battery Lock Latch: passo 5, imagem 1 %32
    • Slide the battery lock latch to the lock position.
Conclusão
Terrence15
Membro desde: 12/18/17
79.243 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.989 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 177
