Ir para o conteúdo principal
Dell Inspiron 13 7378 Wi-Fi Card Replacement
O que você precisa
  1. Dell Inspiron 13 7378 Wi-Fi Card Replacement, Back Cover: passo 1, imagem 1 %32
    • Set the laptop with its underside facing up for improved accessibility.
  2. Dell Inspiron 13 7378 Wi-Fi Card Replacement: passo 2, imagem 1 %32 Dell Inspiron 13 7378 Wi-Fi Card Replacement: passo 2, imagem 2 %32
    • Using a Phillips #00 screwdriver, extract the nine 3 mm screws located on the back of the laptop.
  3. Dell Inspiron 13 7378 Wi-Fi Card Replacement: passo 3, imagem 1 %32 Dell Inspiron 13 7378 Wi-Fi Card Replacement: passo 3, imagem 2 %32 Dell Inspiron 13 7378 Wi-Fi Card Replacement: passo 3, imagem 3 %32
    • Carefully pry open the back of the back of the laptop using opening picks.
    • Carefully raise and detach the back cover from the laptop.
    • Exercise caution to prevent damaging or cracking the device's back cover.
  4. Dell Inspiron 13 7378 Wi-Fi Card Replacement, Wi-Fi Card: passo 4, imagem 1 %32 Dell Inspiron 13 7378 Wi-Fi Card Replacement, Wi-Fi Card: passo 4, imagem 2 %32
    • Remove the single 3 mm screw from the Wi-Fi card using a Phillips #1 screwdriver.
  5. Dell Inspiron 13 7378 Wi-Fi Card Replacement: passo 5, imagem 1 %32
    • Use your fingers to pull the Wi-Fi card upwards from the slot of the motherboard.
    • Take caution in pulling out the Wi-Fi card; two cable connectors are still attached.
  6. Dell Inspiron 13 7378 Wi-Fi Card Replacement: passo 6, imagem 1 %32
    • Disconnect the two wires attached to the Wi-Fi card.
    • Remove the Wi-Fi card from the laptop.
Conclusão
Uma outra pessoa concluiu este guia.
Samantha Gonzalez
Membro desde: 02/08/22
298 Reputação
Autoria de 2 guias
Equipe
Gateway, Team 1-3, Saknee Spring 2022 Membro de Gateway, Team 1-3, Saknee Spring 2022
GCC-SAKNEE-S22S1G3
Membros da 5
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 254
