Introdução
One of the common defects that Dell Inspiron 13 7378 is currently facing has been the complete shut off or pitch-black screen that pops out of nowhere. That may have a lot to do with the battery and could also potentially mean it's damaged.
Before following this guide make sure the device is powered off as this can be a dangerous hazard. You will then be able to safely replace your battery and return your computer back to its proper function.
O que você precisa
Replace the back cover to complete the process.
6 outras pessoas executaram este guia.
