Pular para o conteúdo principal
Introdução
In this guide, we will show you how to remove and replace the Memory Modules.
Peças
Nenhum componente especificado.
  1. WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer.  After working inside your computer, follow the instructions in After Working Inside Your Computer.
  2. Remove the screws that secure the battery to the palm-rest assembly.
    • Remove the screws that secure the battery to the palm-rest assembly.
  3. Lift the battery off the palm-rest assembly.
    • Lift the battery off the palm-rest assembly.
    • Press and hold the power button for five seconds to ground the system board.
  4. Align the screw holes on the battery with the screw holes on the palm-rest assembly.
    • Align the screw holes on the battery with the screw holes on the palm-rest assembly.
  5. Kit de Reparo de Bateria do MacBook
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  6. Replace the screws that secure the battery to the palm-rest assembly.
    • Replace the screws that secure the battery to the palm-rest assembly.
  7. Connect the battery cable to the system board.
    • Connect the battery cable to the system board.
  8. WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer.  After working inside your computer, follow the instructions in After Working Inside Your Computer.
  9. Use your fingertips to carefully spread apart the securing-clips on each end of the memory-module slot until the memory module pops up.
    • Use your fingertips to carefully spread apart the securing-clips on each end of the memory-module slot until the memory module pops up.
  10. Remove the memory module from the memory-module slot. Remove the memory module from the memory-module slot.
    • Remove the memory module from the memory-module slot.
  11. Lift the Mylar to access the memory-module slot.
    • Lift the Mylar to access the memory-module slot.
  12. Align the notch on the memory module with the tab on the memory-module slot.
    • Align the notch on the memory module with the tab on the memory-module slot.
  13. Slide the memory module firmly into the slot at an angle and press the memory module down until it clicks into place.
    • Slide the memory module firmly into the slot at an angle and press the memory module down until it clicks into place.
    • NOTE: If you do not hear the click, remove the memory module and reinstall it.
Linha de Chegada
Terrence15
Membro desde: 18-12-2017
70.785 reputação
431 Guias de autoria
Equipe
Informative Technologies Inc. Membro de Informative Technologies Inc.
Community
15 Membros
914 Guias de autoria
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Todo: 83
