Ir para o conteúdo principal
Dell Inspiron 13 7368 Display Assembly Replacement
O que você precisa
  1. Dell Inspiron 13 7368 Display Assembly Replacement, Peeling the Tape: passo 1, imagem 1 %32 Dell Inspiron 13 7368 Display Assembly Replacement, Peeling the Tape: passo 1, imagem 2 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Peel off the pieces of tape that secure the display cable and touch-screen board-cable to the system board.
  2. Dell Inspiron 13 7368 Display Assembly Replacement, Disconnecting the Display Cable: passo 2, imagem 1 %32 Dell Inspiron 13 7368 Display Assembly Replacement, Disconnecting the Display Cable: passo 2, imagem 2 %32
    • Open the latches to disconnect the display cable and the touch-screen board-cable from the system board.
  3. Dell Inspiron 13 7368 Display Assembly Replacement, Open the Display: passo 3, imagem 1 %32
    • Turn the computer over and open the display as far as possible.
    • CAUTION: Place the computer on a soft and clean surface to avoid scratching the display.
  4. Dell Inspiron 13 7368 Display Assembly Replacement, Remove the Screws: passo 4, imagem 1 %32
    • Remove the screws that secure the display assembly to the palm-rest assembly.
  5. Dell Inspiron 13 7368 Display Assembly Replacement, Lifting the Display Assembly: passo 5, imagem 1 %32
    • Lift the display assembly off the palm-rest assembly.
  6. Dell Inspiron 13 7368 Display Assembly Replacement, Placing the Display Assembly: passo 6, imagem 1 %32
    • Place the display assembly face down on the palm-rest assembly.
  7. Dell Inspiron 13 7368 Display Assembly Replacement, Align the Screw Holes: passo 7, imagem 1 %32
    • Align the screw holes on the display hinges with the screw holes on the palm-rest assembly.
  8. Dell Inspiron 13 7368 Display Assembly Replacement, Replace the Screws: passo 8, imagem 1 %32
    • Replace the screws that secure the display assembly to the palm-rest assembly.
  9. Dell Inspiron 13 7368 Display Assembly Replacement, Sliding the Display Cable: passo 9, imagem 1 %32
    • Close the display and turn the computer over.
    • Slide the display cable and the touch-screen board-cable into their respective connectors on the system board and close the latches to secure the cables.
  10. Dell Inspiron 13 7368 Display Assembly Replacement, Adhering the Tape: passo 10, imagem 1 %32
    • Adhere the pieces of tape that secure the display cable and the touch-screen board-cable to their respective connectors on the system board.
Conclusão
Uma outra pessoa concluiu este guia.
Terrence15
Membro desde: 12/18/17
79.243 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.989 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 1,104
