Introdução
In this guide, we will show you how to remove and replace the Display Assembly.
O que você precisa
Peel off the pieces of tape that secure the display cable and touch-screen board-cable to the system board.
Open the latches to disconnect the display cable and the touch-screen board-cable from the system board.
Remove the screws that secure the display assembly to the palm-rest assembly.
Place the display assembly face down on the palm-rest assembly.
Align the screw holes on the display hinges with the screw holes on the palm-rest assembly.
Replace the screws that secure the display assembly to the palm-rest assembly.
Close the display and turn the computer over.
Slide the display cable and the touch-screen board-cable into their respective connectors on the system board and close the latches to secure the cables.
Adhere the pieces of tape that secure the display cable and the touch-screen board-cable to their respective connectors on the system board.
Uma outra pessoa concluiu este guia.
