Introdução
In this guide, we will show you how to remove and replace the Display Assembly.
O que você precisa
Make a note of the Mini-Card antenna cable routing and carefully dislodge the antenna cables from the routing guides on the computer base. Pull the cables away so that they are clear of the computer base.
Remove the four screws that secure the display assembly to the computer base.
Slide the tabs on the display hinges into the slots in the computer base.
Align the display assembly with the computer base using the alignment posts on the computer base and set the display assembly in place. Ensure the display cable and Mini-Card antenna cables route correctly through the display hinge covers.
Replace the four screws that secure the display assembly to the computer base.
Route the Mini-Card antenna cables through the routing guides on the computer base.
