Ir para o conteúdo principal
Dell Inspiron 13 1370 Battery Replacement
  1. Dell Inspiron 13 1370 Battery Replacement, Turn Over the Computer: passo 1, imagem 1 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • Turn the computer upside down on a clean, flat surface.
  2. Dell Inspiron 13 1370 Battery Replacement, Sliding the Battery: passo 2, imagem 1 %32
    • Slide the battery release latch to the unlock position.The battery release latch automatically shifts to the locked position when you remove the battery.
  3. Dell Inspiron 13 1370 Battery Replacement, Sliding the Battery Lock Latch: passo 3, imagem 1 %32
    • Slide the battery lock latch to the unlock position.
  4. Dell Inspiron 13 1370 Battery Replacement, Lifting the Battery: passo 4, imagem 1 %32 Dell Inspiron 13 1370 Battery Replacement, Lifting the Battery: passo 4, imagem 2 %32
    • At the notch, lift the battery to remove it from the battery bay.
  5. Dell Inspiron 13 1370 Battery Replacement, Placing the Battery: passo 5, imagem 1 %32 Dell Inspiron 13 1370 Battery Replacement, Placing the Battery: passo 5, imagem 2 %32
    • Place the NEW battery in the battery bay.
  6. Dell Inspiron 13 1370 Battery Replacement, Push Down on the Battery: passo 6, imagem 1 %32
    • Push down on the battery to connect it to the computer.
  7. Dell Inspiron 13 1370 Battery Replacement, Sliding the Latch: passo 7, imagem 1 %32
    • Slide the battery lock latch to the locked position.
Linha de Chegada
Terrence15
Membro desde: 12/18/17
79.243 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.989 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 289
