Ir para o conteúdo principal
Dell Inspiron 1210 Hard Drive Replacement
O que você precisa
  1. Dell Inspiron 1210 Hard Drive Replacement, Removing the Hard Drive Cable: passo 1, imagem 1 %32
    • CAUTION: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • NOTICE: When the hard drive is not in the computer, store it in protective anti-static packaging (see "Protecting Against Electrostatic Discharge" in the safety instructions that shipped with your computer).
    • Remove the hard drive cable from the hard-drive system board connector.
  2. Dell Inspiron 1210 Hard Drive Replacement, Lifting the Hard Drive: passo 2, imagem 1 %32 Dell Inspiron 1210 Hard Drive Replacement, Lifting the Hard Drive: passo 2, imagem 2 %32
    • Lift the hard drive out of the hard drive compartment.
  3. Dell Inspiron 1210 Hard Drive Replacement, Detach the Cable: passo 3, imagem 1 %32
    • Detach the hard drive cable from the hard drive cable connector.
  4. Dell Inspiron 1210 Hard Drive Replacement, Remove the Hard Drive: passo 4, imagem 1 %32
    • Remove the hard drive from the rubber case.
  5. Dell Inspiron 1210 Hard Drive Replacement, Attaching the Hard Drive Cable: passo 5, imagem 1 %32
    • To replace the hard drive, replace the rubber case onto the hard drive.
    • Attach the hard drive cable to the hard drive cable connector.
  6. Dell Inspiron 1210 Hard Drive Replacement, Placing the Hard Drive: passo 6, imagem 1 %32
    • Place the NEW hard drive in the hard drive compartment.
  7. Dell Inspiron 1210 Hard Drive Replacement, Attaching the Hard Drive Cable: passo 7, imagem 1 %32
    • Attach the hard drive cable to the hard-drive system board connector.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Terrence15
Membro desde: 12/18/17
79.243 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.989 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 16
Duração total: 1,061
