Introdução
In this guide, we will be showing you how to remove and replace the Memory Modules.
Peças
Não são necessárias peças.
  1. Follow the instructions in "Before Working Inside Your Computer."
  2. Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
  3. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  4. Remove the module from the connector.
    • Remove the module from the connector.
  5. NOTE: If the memory module is not installed properly, the computer may not boot properly. No error message indicates this failure.
    • NOTE: If the memory module is not installed properly, the computer may not boot properly. No error message indicates this failure.
    • Align the notch in the module edge connector with the tab in the connector slot.
  6. Slide the NEW module firmly into the slot at a 45-degree angle, and rotate the module down until it clicks into place. If you do not feel the click, remove the module and reinstall it.
    • Slide the NEW module firmly into the slot at a 45-degree angle, and rotate the module down until it clicks into place. If you do not feel the click, remove the module and reinstall it.
  7. Replace the cover and tighten the captive screw. Replace the cover and tighten the captive screw.
    • Replace the cover and tighten the captive screw.
Linha de Chegada
Terrence15
70.304 reputação
442 Guides authored
Equipe
Informative Technologies Inc. Membro de Informative Technologies Inc.
Community
15 Membros
925 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Todo: 23
