Introdução
RAM is used whenever any sort of application is open on your computer. The more applications that are open, the more RAM that is being used. If you find that your computer is not capable of running apps at decent speed then replacing the RAM can help fix that issue.
O que você precisa
Slide the latches outward to release the battery.
Pull the battery outward to remove.
With a Phillips #1, loosen the 1 mm screw attaching the access door to the laptop body
Using your fingers, remove the access door to expose the memory card
