Ir para o conteúdo principal
Dell Inspiron 11z-1121 RAM Replacement
O que você precisa
  1. Dell Inspiron 11z-1121 RAM Replacement, Battery: passo 1, imagem 1 %32 Dell Inspiron 11z-1121 RAM Replacement, Battery: passo 1, imagem 2 %32
    • Slide the latches outward to release the battery.
    • Pull the battery outward to remove.
    • The latches should lock in place, allowing for easy removal.
    • The battery must be removed for safety reasons when replacing other components of the laptop.
  2. Dell Inspiron 11z-1121 RAM Replacement, RAM: passo 2, imagem 1 %32 Dell Inspiron 11z-1121 RAM Replacement, RAM: passo 2, imagem 2 %32
    • With a Phillips #1, loosen the 1 mm screw attaching the access door to the laptop body
    • Using your fingers, remove the access door to expose the memory card
  3. Dell Inspiron 11z-1121 RAM Replacement: passo 3, imagem 1 %32 Dell Inspiron 11z-1121 RAM Replacement: passo 3, imagem 2 %32
    • To access the memory card, push out the lashes on the left and the right of the memory card.
    • To remove the memory card, use your fingers to pull it out with the lashes still stretched out.
Conclusão
Equipe
USF Tampa, Team 1-5, Nance Fall 2016 Membro de USF Tampa, Team 1-5, Nance Fall 2016
USFT-NANCE-F16S1G5
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 20
Duração total: 475
