Ir para o conteúdo principal
Dell Inspiron 11z-1121 Memory Modules Replacement
O que você precisa
  1. Dell Inspiron 11z-1121 Memory Modules Replacement, Loosen the Screw: passo 1, imagem 1 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Loosen the captive screw that secures the memory-module cover to the computer base.
  2. Dell Inspiron 11z-1121 Memory Modules Replacement, Lifting the Memory-Module Cover: passo 2, imagem 1 %32
    • Lift the memory-module cover off the computer base.
  3. Dell Inspiron 11z-1121 Memory Modules Replacement, Popping up the Memory Module: passo 3, imagem 1 %32
    • CAUTION: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
  4. Dell Inspiron 11z-1121 Memory Modules Replacement, Removing the Memory Module: passo 4, imagem 1 %32
    • Remove the memory module from the memory-module connector.
  5. Dell Inspiron 11z-1121 Memory Modules Replacement, Align the Notch: passo 5, imagem 1 %32
    • Align the notch in the NEW memory module with the tab in the memory-module connector.
  6. Dell Inspiron 11z-1121 Memory Modules Replacement, Sliding the Memory Module: passo 6, imagem 1 %32 Dell Inspiron 11z-1121 Memory Modules Replacement, Sliding the Memory Module: passo 6, imagem 2 %32
    • Slide the memory module firmly into the memory-module connector at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
  7. Dell Inspiron 11z-1121 Memory Modules Replacement, Sliding the Tabs: passo 7, imagem 1 %32
    • Slide the tabs on the memory-module cover into the slots on the computer base and gently press the memory-module cover into place.
  8. Dell Inspiron 11z-1121 Memory Modules Replacement, Tighten the Screw: passo 8, imagem 1 %32
    • Tighten the screw that secures the memory-module cover to the computer base.
Conclusão
Terrence15
Membro desde: 12/18/17
79.121 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.985 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 151
