Ir para o conteúdo principal
Dell Inspiron 11z-1121 Display Assembly Replacement
O que você precisa
  1. Dell Inspiron 11z-1121 Display Assembly Replacement, Disconnecting the Mini-Card Cables: passo 1, imagem 1 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • Disconnect the Mini-Card antenna cables from the Mini-Card(s).
  2. Dell Inspiron 11z-1121 Display Assembly Replacement, Dislodge the Cables: passo 2, imagem 1 %32
    • Make note of the cable routing and carefully dislodge the Mini-Card antenna cables from the routing guides.
  3. Dell Inspiron 11z-1121 Display Assembly Replacement, Disconnecting the Display Cable: passo 3, imagem 1 %32
    • Disconnect the display cable from the system board connector.
  4. Dell Inspiron 11z-1121 Display Assembly Replacement, Remove the Screws: passo 4, imagem 1 %32
    • Remove the two screws (one on each side) that secure the display assembly to the computer base.
  5. Dell Inspiron 11z-1121 Display Assembly Replacement, Lifting and Removing the Display Assembly: passo 5, imagem 1 %32
    • Lift and remove the display assembly off the computer base.
  6. Dell Inspiron 11z-1121 Display Assembly Replacement, Replace the Screws: passo 6, imagem 1 %32
    • Place the NEW display assembly in position and replace the two screws (one on each side) that secure the display assembly to the computer base.
  7. Dell Inspiron 11z-1121 Display Assembly Replacement, Connecting the Display Cable: passo 7, imagem 1 %32
    • Connect the display cable to the system board connector.
  8. Dell Inspiron 11z-1121 Display Assembly Replacement, Routing the Cables: passo 8, imagem 1 %32
    • Route the Mini-Card antenna cables through the routing guides on the computer base.
  9. Dell Inspiron 11z-1121 Display Assembly Replacement, Connecting the Cables: passo 9, imagem 1 %32
    • Connect the Mini-Card antenna cables to the Mini-Card(s).
Conclusão
Terrence15
Membro desde: 12/18/17
79.243 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.989 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 274
