Ir para o conteúdo principal
Dell Inspiron 11z 1120 Display Assembly Replacement
O que você precisa
  1. Dell Inspiron 11z 1120 Display Assembly Replacement, Disconnecting the Antenna Cables: passo 1, imagem 1 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • Disconnect the Mini-Card antenna cables from the Mini-Card(s).
  2. Dell Inspiron 11z 1120 Display Assembly Replacement, Remove the Screws: passo 2, imagem 1 %32
    • Remove the two screws (one on each side) that secure the display assembly to the computer base.
  3. Dell Inspiron 11z 1120 Display Assembly Replacement, Lifting the Display Assembly: passo 3, imagem 1 %32
    • Lift and remove the display assembly off the computer base.
  4. Dell Inspiron 11z 1120 Display Assembly Replacement, Place the Display Assembly: passo 4, imagem 1 %32 Dell Inspiron 11z 1120 Display Assembly Replacement, Place the Display Assembly: passo 4, imagem 2 %32
    • Place the NEW display assembly in position and replace the two screws (one on each side) that secure the display assembly to the computer base.
  5. Dell Inspiron 11z 1120 Display Assembly Replacement, Connect the Display Cable: passo 5, imagem 1 %32
    • Connect the display cable to the system board connector.
  6. Dell Inspiron 11z 1120 Display Assembly Replacement, Routing the Antenna Cables: passo 6, imagem 1 %32
    • Route the Mini-Card antenna cables through the routing guides on the computer base.
  7. Dell Inspiron 11z 1120 Display Assembly Replacement, Connecting the Mini-Card Cables: passo 7, imagem 1 %32
    • Connect the Mini-Card antenna cables to the Mini-Card(s).
Conclusão
Terrence15
Membro desde: 12/18/17
79.131 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.986 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 148
