Ir para o conteúdo principal
Dell Inspiron 11z 1110 Display Assembly Replacement
O que você precisa
  1. Dell Inspiron 11z 1110 Display Assembly Replacement, Dislodge the Mini-Card Antenna Cables: passo 1, imagem 1 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Make note of the cable routing and carefully dislodge the Mini-Card antenna cables from the routing guides.
  2. Dell Inspiron 11z 1110 Display Assembly Replacement, Disconnecting the Display Cable: passo 2, imagem 1 %32
    • Disconnect the display cable and the camera cable from the system board connectors.
  3. Dell Inspiron 11z 1110 Display Assembly Replacement, Remove the Screws: passo 3, imagem 1 %32
    • Remove the two screws (one on each side) that secure the display assembly to the computer base.
  4. Dell Inspiron 11z 1110 Display Assembly Replacement, Lifting the Display Assembly: passo 4, imagem 1 %32
    • Lift the display assembly off the computer.
  5. Dell Inspiron 11z 1110 Display Assembly Replacement, Placing the Display Assembly: passo 5, imagem 1 %32
    • Place the NEW display assembly in position and replace the two screws (one on each side) that secure the display assembly to the computer base.
  6. Dell Inspiron 11z 1110 Display Assembly Replacement, Routing the Mini-Card Antenna Cables: passo 6, imagem 1 %32
    • Route the Mini-Card antenna cables through the routing guides.
Conclusão
Terrence15
Membro desde: 12/18/17
79.061 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.985 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 255
