Introdução
In this guide, we will show you how to remove and replace the Display Assembly.
Peças
Não são necessárias peças.
  1. Follow the instructions in Before You Begin.
    • Follow the instructions in Before You Begin.
    • Disconnect the Mini-Card antenna cables from the Mini-Card(s).
  2. Make note of the cable routing and carefully dislodge the Mini-Card antenna cables from the routing guides.
    • Make note of the cable routing and carefully dislodge the Mini-Card antenna cables from the routing guides.
    • Disconnect the display cable from the system board connector.
    • Remove the two screws (one on each side) that secure the display assembly to the computer base.
    • Lift and remove the display assembly off the computer base.
    • Place the NEW display assembly in position and replace the two screws (one on each side) that secure the display assembly to the computer base.
    • Connect the display cable to the system board connector.
    • Route the Mini-Card antenna cables through the routing guides on the computer base.
    • Connect the Mini-Card antenna cables to the Mini-Card(s).
Conclusão
Terrence15
70.228 reputação
442 Guides authored
Equipe
Informative Technologies Inc. Membro de Informative Technologies Inc.
Community
15 Membros
925 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Todo: 23
