Ir para o conteúdo principal
Dell Inspiron 1100 Wireless Card Replacement
O que você precisa
  1. Dell Inspiron 1100 Wireless Card Replacement, Wireless Card: passo 1, imagem 1 %32 Dell Inspiron 1100 Wireless Card Replacement, Wireless Card: passo 1, imagem 2 %32
    • Unscrew the one Phillips #0 screw at the bottom of the panel and remove the panel.
    • The screw does not separate from the cover. Be sure the screw is completely unscrewed before using force to remove the cover.
  2. Dell Inspiron 1100 Wireless Card Replacement: passo 2, imagem 1 %32 Dell Inspiron 1100 Wireless Card Replacement: passo 2, imagem 2 %32
    • Unscrew the two 3mm Phillips #0 screws located on the card.
    • Be careful, as these screws are easy to strip.
  3. Dell Inspiron 1100 Wireless Card Replacement: passo 3, imagem 1 %32 Dell Inspiron 1100 Wireless Card Replacement: passo 3, imagem 2 %32
    • Pull the white plastic tab on top of the card straight up to remove the card.
    • This step requires some light force. Be sure the screws from the previous step have been removed.
  4. Dell Inspiron 1100 Wireless Card Replacement: passo 4, imagem 1 %32
    • Use blunt nose tweezers to remove the power cable from the wireless card.
    • Make sure the tweezers are only gripping the head of the power cable and not any part of the wireless card, as this may damage the card.
Conclusão
Alexander Pacheco
Membro desde: 10/19/16
610 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 3-3, Isaacson Fall 2016 Membro de UMass Dartmouth, Team 3-3, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G3
Membros da 3
Autoria de 9 guias
2 comentários
I believe that is a phone modem, not a wireless card. Might be wrong though.
George A. - Responder
i think your right as dell 1100 dont have a wifi slot only can use usb or pcmcia card
Conner Peden - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 628
