Ir para o conteúdo principal
Dell Inspiron 1100 Display Assembly Removal
O que você precisa
  1. Dell Inspiron 1100 Display Assembly Removal, Remove the Screws: passo 1, imagem 1 %32 Dell Inspiron 1100 Display Assembly Removal, Remove the Screws: passo 1, imagem 2 %32
    • Follow the instructions in "Preparing to Work Inside the Computer."
    • CAUTION: To prevent static damage to components inside your computer, discharge static electricity from your body before you touch any of your computer's electronic components. You can do so by touching an unpainted metal surface.
    • Close the display.
    • From the back of the computer, remove the two M2.5 x 5-mm screws labeled "circle D."
  2. Dell Inspiron 1100 Display Assembly Removal, Opening the Display Assembly: passo 2, imagem 1 %32
    • Open the display assembly approximately 180 degrees, and support the display assembly so that it does not open past this position.
  3. Dell Inspiron 1100 Display Assembly Removal, Remove the Screws: passo 3, imagem 1 %32
    • Remove the two M2.5 x 5-mm screws from each hinge bracket.
  4. Dell Inspiron 1100 Display Assembly Removal, Disconnecting the Cable: passo 4, imagem 1 %32
    • Pull straight up on the pull-tab that is attached to the display-feed flex cable to disconnect the cable from the system board.
  5. Dell Inspiron 1100 Display Assembly Removal, Lifting the Display Assembly: passo 5, imagem 1 %32
    • Lift the display assembly up and out of the computer base.
Conclusão
Terrence15
Membro desde: 12/18/17
79.121 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.985 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 337
