Introdução
To replace parts of the Chromebook, you need to remove the bottom plate. This guide will show you how to efficiently and easily remove the bottom plate so you can continue to fix what your Chromebook needs.
O que você precisa
Flip the Chromebook to have the bottom facing you.
Make a note of all of the screws present. You may need to uncover some of them hidden beneath plastic tabs. The location of each screw is marked in the accompanying image.
Ferramenta utilizada nesse passo:Tweezers$4.99
Before you completely pull off the back, you must disconnect the MB cord.
Using blunt-nosed tweezers, carefully flip the black bar that keeps the MB cord latched in as circled in the image.
Once open, grab the flat cord with your tweezers and pull horizontally until it comes free. Your bottom plate is now fully removed.
Uma outra pessoa concluiu este guia.
