Ir para o conteúdo principal
Dell Inspiron 11-3168 Wifi module Replacement
O que você precisa
  1. Dell Inspiron 11-3168 Wifi module Replacement, Battery: passo 1, imagem 1 %32 Dell Inspiron 11-3168 Wifi module Replacement, Battery: passo 1, imagem 2 %32
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Using a Phillips #00 screwdriver, remove all nine 7.5mm screws from the bottom case of the laptop.
  2. Dell Inspiron 11-3168 Wifi module Replacement: passo 2, imagem 1 %32 Dell Inspiron 11-3168 Wifi module Replacement: passo 2, imagem 2 %32 Dell Inspiron 11-3168 Wifi module Replacement: passo 2, imagem 3 %32
    • Remove the bottom case of the laptop by gently prying along the seam with a plastic opening tool.
  3. Dell Inspiron 11-3168 Wifi module Replacement: passo 3, imagem 1 %32 Dell Inspiron 11-3168 Wifi module Replacement: passo 3, imagem 2 %32
    • Remove the one 7.5mm screw that is holding the battery in place.
  4. Dell Inspiron 11-3168 Wifi module Replacement: passo 4, imagem 1 %32 Dell Inspiron 11-3168 Wifi module Replacement: passo 4, imagem 2 %32
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
  5. Dell Inspiron 11-3168 Wifi module Replacement: passo 5, imagem 1 %32 Dell Inspiron 11-3168 Wifi module Replacement: passo 5, imagem 2 %32 Dell Inspiron 11-3168 Wifi module Replacement: passo 5, imagem 3 %32
    • Remove the battery.
  6. Dell Inspiron 11-3168 Wifi module Replacement, Wifi module: passo 6, imagem 1 %32 Dell Inspiron 11-3168 Wifi module Replacement, Wifi module: passo 6, imagem 2 %32 Dell Inspiron 11-3168 Wifi module Replacement, Wifi module: passo 6, imagem 3 %32
    • Use an opening tool or your fingers to release the clamps on both ends of the ribbon cable and lift away.
  7. Dell Inspiron 11-3168 Wifi module Replacement: passo 7, imagem 1 %32 Dell Inspiron 11-3168 Wifi module Replacement: passo 7, imagem 2 %32 Dell Inspiron 11-3168 Wifi module Replacement: passo 7, imagem 3 %32
    • Use a Phillips #00 screwdriver to remove the screw that is holding the WiFi module in place.
    • Remove the metal piece that covers the antenna cable connectors.
  8. Dell Inspiron 11-3168 Wifi module Replacement: passo 8, imagem 1 %32 Dell Inspiron 11-3168 Wifi module Replacement: passo 8, imagem 2 %32 Dell Inspiron 11-3168 Wifi module Replacement: passo 8, imagem 3 %32
    • To remove the WiFi module from the motherboard, slide it free of the socket connector.
  9. Dell Inspiron 11-3168 Wifi module Replacement: passo 9, imagem 1 %32 Dell Inspiron 11-3168 Wifi module Replacement: passo 9, imagem 2 %32 Dell Inspiron 11-3168 Wifi module Replacement: passo 9, imagem 3 %32
    • Disconnect both the black and the white wires from the WiFi module.
Conclusão
To install the replacement module, start at step 4 and work your way backwards to step 1.
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 509
