Introdução
This guide will show you how to replace the hard drive of the Dell Inspiron 11-3168. Before starting, make sure both the laptop AC adapter and battery are disconnected prior to replacing any part or component.
Note: This guide does not apply to Celeron eMMC systems. These have the storage space soldered to the board and require a motherboard replacement.
O que você precisa
Using a Phillips #00 screwdriver, remove all nine 7.5mm screws from the bottom case of the laptop.
