Ir para o conteúdo principal
Dell Inspiron 11-3168 Hard Drive Replacement
O que você precisa
  1. Dell Inspiron 11-3168 Hard Drive Replacement, Battery: passo 1, imagem 1 %32 Dell Inspiron 11-3168 Hard Drive Replacement, Battery: passo 1, imagem 2 %32
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Using a Phillips #00 screwdriver, remove all nine 7.5mm screws from the bottom case of the laptop.
  2. Dell Inspiron 11-3168 Hard Drive Replacement: passo 2, imagem 1 %32 Dell Inspiron 11-3168 Hard Drive Replacement: passo 2, imagem 2 %32 Dell Inspiron 11-3168 Hard Drive Replacement: passo 2, imagem 3 %32
    • Remove the bottom case of the laptop by gently prying along the seam with a plastic opening tool.
  3. Dell Inspiron 11-3168 Hard Drive Replacement: passo 3, imagem 1 %32 Dell Inspiron 11-3168 Hard Drive Replacement: passo 3, imagem 2 %32
    • Remove the one 7.5mm screw that is holding the battery in place.
  4. Dell Inspiron 11-3168 Hard Drive Replacement: passo 4, imagem 1 %32 Dell Inspiron 11-3168 Hard Drive Replacement: passo 4, imagem 2 %32
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
  5. Dell Inspiron 11-3168 Hard Drive Replacement: passo 5, imagem 1 %32 Dell Inspiron 11-3168 Hard Drive Replacement: passo 5, imagem 2 %32 Dell Inspiron 11-3168 Hard Drive Replacement: passo 5, imagem 3 %32
    • Remove the battery.
  6. Dell Inspiron 11-3168 Hard Drive Replacement, Hard Drive: passo 6, imagem 1 %32 Dell Inspiron 11-3168 Hard Drive Replacement, Hard Drive: passo 6, imagem 2 %32
    • Unscrew the two 7.5 mm Phillips #00 screws.
  7. Dell Inspiron 11-3168 Hard Drive Replacement: passo 7, imagem 1 %32 Dell Inspiron 11-3168 Hard Drive Replacement: passo 7, imagem 2 %32 Dell Inspiron 11-3168 Hard Drive Replacement: passo 7, imagem 3 %32
    • Lift the hard drive out of the laptop.
Conclusão
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 43
Ao todo: 2,696
