Ir para o conteúdo principal
Dell Inspiron 11-3164 Speaker Assembly Replacement
O que você precisa
  1. Dell Inspiron 11-3164 Speaker Assembly Replacement, Speaker Assembly: passo 1, imagem 1 %32 Dell Inspiron 11-3164 Speaker Assembly Replacement, Speaker Assembly: passo 1, imagem 2 %32
    • Remove the eight 6mm back panel screws with your PH1 Phillips head screw driver bit.
    • Use your screw driver to remove the plastic cover in the center of the laptop.
    • Using a PH1 Phillips head screw driver bit remove the last 6mm screw.
  2. Dell Inspiron 11-3164 Speaker Assembly Replacement: passo 2, imagem 1 %32 Dell Inspiron 11-3164 Speaker Assembly Replacement: passo 2, imagem 2 %32
    • Use your metal pry tool to pry around the laptop until the two pieces separate.
    • There will be a ribbon cable holding the two pieces together, be careful not to rip it out of it's socket.
    • Use your metal pry tool to release the connector.
  3. Dell Inspiron 11-3164 Speaker Assembly Replacement: passo 3, imagem 1 %32 Dell Inspiron 11-3164 Speaker Assembly Replacement: passo 3, imagem 2 %32
    • Remove the speaker plug from it's socket.
    • Lift the speaker assembly from the case.
Conclusão
Equipe
USF Tampa, Team S6-G4, Eyestone Spring 2018 Membro de USF Tampa, Team S6-G4, Eyestone Spring 2018
USFT-EYESTONE-S18S6G4
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 149
