Ir para o conteúdo principal
Dell Inspiron 11-3164 Screen Replacement
O que você precisa
  1. Dell Inspiron 11-3164 Screen Replacement, Screen: passo 1, imagem 1 %32 Dell Inspiron 11-3164 Screen Replacement, Screen: passo 1, imagem 2 %32
    • Lay the laptop flat with its bottom up exposing the screws holding it together. Unscrew these eight screws with a JIS #1 screwdriver and put them aside.
    • Use your screw driver to pry off the plastic cover exposing the last screw in the middle.
    • Remove the screw and save the plastic cover to put back on later when done.
  2. Dell Inspiron 11-3164 Screen Replacement: passo 2, imagem 1 %32
    • Remove this one screw with the JIS #1 screwdriver in order to take of the holding plate for the wifi card adapter. Then remove the adapter.
    • Unscrew these two screws with a JIS#1 screwdriver.
    • Peel back the two metal brackets to remove the screen.
Conclusão
Equipe
USF Tampa, Team S6-G4, Eyestone Spring 2018 Membro de USF Tampa, Team S6-G4, Eyestone Spring 2018
USFT-EYESTONE-S18S6G4
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Duração total: 176
