Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Place laptop upside down to observe the first set of screws on the bottom cover. With the J1 Phillips head screwdriver bit, unscrew eight (8) size 60 mm screws.
With a metal spudger, remove the plastic cover to unveil the final screw.
With the J1 Phillips head bit, remove remaining 60 mm screw.
With a metal spudger, pry apart the bottom cover working around the edges.
With tweezers, disconnect the USB/Audio circuit board cable.
Place the bottom cover off to the side.
With the J1 screwdriver bit, unscrew three (3) size 40 mm battery screws.
With tweezers, disconnect the battery cable.
Remove the battery pack.
With tweezers, disconnect the keyboard cable
With tweezers, disconnect the touchpad cable.
With the Philips #00 Screwdriver, loosen the 4 - M2 x 2mm screws
Gently remove the mouse touchpad.
Uma outra pessoa concluiu este guia.
