Ir para o conteúdo principal
Dell Inspiron 11-3164 Motherboard Replacement
O que você precisa
  1. Dell Inspiron 11-3164 Motherboard Replacement, Motherboard: passo 1, imagem 1 %32 Dell Inspiron 11-3164 Motherboard Replacement, Motherboard: passo 1, imagem 2 %32
    • Start by placing the laptop upside down to expose the first set of screws on the bottom of the laptop. Use your J1 Phillips head screwdriver bit to unscrew the 8 size 60 mm screws.
    • Remove the plastic cover to unveil the final screw holding the front and back frame together.
    • Remove this last screw of size 60mm with the J1 phillips head bit found in the approved iFixit toolkit.
  2. Dell Inspiron 11-3164 Motherboard Replacement: passo 2, imagem 1 %32 Dell Inspiron 11-3164 Motherboard Replacement: passo 2, imagem 2 %32
    • Open the latches and disconnect the touch-pad cable and keyboard cable from the system board.
  3. Dell Inspiron 11-3164 Motherboard Replacement: passo 3, imagem 1 %32 Dell Inspiron 11-3164 Motherboard Replacement: passo 3, imagem 2 %32
    • Disconnect the battery cable from the system board.
    • Remove the screws that secure the battery to the palm rest and keyboard assembly by using the PH1 screw driver to unscrew the three size 40 mm battery screws.
    • There is no way that motherboard can be removed with battery pack still attached to the laptop.
  4. Dell Inspiron 11-3164 Motherboard Replacement: passo 4, imagem 1 %32
    • Open the latch and disconnect the I/O-board cable from system board.
  5. Dell Inspiron 11-3164 Motherboard Replacement: passo 5, imagem 1 %32 Dell Inspiron 11-3164 Motherboard Replacement: passo 5, imagem 2 %32
    • Remove the 2mm screw that secures the motherboard and keyboard assembly.
  6. Dell Inspiron 11-3164 Motherboard Replacement: passo 6, imagem 1 %32 Dell Inspiron 11-3164 Motherboard Replacement: passo 6, imagem 2 %32
    • Disconnect the coin-cell battery cable from the system board.
    • To remove the cable, use a small pliers or Angled Precision Tweezers on the left and right ledges on the adapter.
    • Do not pull by the cord.
  7. Dell Inspiron 11-3164 Motherboard Replacement: passo 7, imagem 1 %32
    • Removing the Wireless WLAN Card
    • Remove the M2 x 3mm bracket screw.
    • Remove the metal bracket.
    • With tweezers, detach the white and black antenna cables connected to the Wireless WLAN Card.
    • Remove the Wireless WLAN Card by slide the assembly out of motherboard wireless socket.
  8. Dell Inspiron 11-3164 Motherboard Replacement: passo 8, imagem 1 %32
    • Disconnect the speaker cable from the system board.
  9. Dell Inspiron 11-3164 Motherboard Replacement: passo 9, imagem 1 %32 Dell Inspiron 11-3164 Motherboard Replacement: passo 9, imagem 2 %32
    • Remove the M2xL3 screw on display-cable guard to the system board.
    • Detach the cable beneath.
  10. Dell Inspiron 11-3164 Motherboard Replacement: passo 10, imagem 1 %32
    • Disconnect the power-adapter port cable from the system board.
    • Use angle precision tweezers to put on the ledge alongside the adapter away from the motherboard socket.
    • Warning: to avoid damaging the cord, do not pull by the cable.
  11. Dell Inspiron 11-3164 Motherboard Replacement: passo 11, imagem 1 %32 Dell Inspiron 11-3164 Motherboard Replacement: passo 11, imagem 2 %32
    • Lift the mother board off the palm rest and keyboard assembly.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
USF Tampa, Team S6-G4, Eyestone Spring 2018 Membro de USF Tampa, Team S6-G4, Eyestone Spring 2018
USFT-EYESTONE-S18S6G4
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 435
