Introdução
If you clicked this link from the troubleshooting guide, follow these steps to help get your wireless back up and running.
O que você precisa
Use tweezers to pry and remove the center screw cover on the back cover.
Use a Phillips screwdriver to unscrew the three 4 mm screws securing the battery.
Use the phillips screwdriver with the PH000 head to unscrew the 3.8mm screw.
4 outras pessoas executaram este guia.
