Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
In this guide, we will show you how to remove and replace the Hard drive.
O que você precisa
Remove the screws that secure the hard-drive assembly to the palm rest and keyboard assembly.
Slide and lift the hard-drive assembly off the palm rest and keyboard assembly.
Remove the screws that secure the hard-drive bracket to the hard drive.
Align the screw holes on the hard drive with the screw holes on the hard-drive bracket.
Replace the screws that secure the hard-drive bracket to the hard drive.
Slide and connect the hard-drive assembly to the connector on the system board.
Align the screw holes on the hard-drive assembly with the screw holes on the palm rest and keyboard assembly
Replace the screws that secure the hard-drive assembly to the palm rest and keyboard assembly.
6 outras pessoas executaram este guia.
Um comentário
Can we replace the harddisk with SSD. Will that increase the performance of the laptop?
