Ir para o conteúdo principal
Dell Inspiron 11-3162 Hard Drive Replacement
O que você precisa
  1. Dell Inspiron 11-3162 Hard Drive Replacement, Remove the Screws: passo 1, imagem 1 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before working inside your computer. After working inside your computer, follow the instructions in After working inside your computer.
    • CAUTION: Hard drives are fragile. Exercise care when handling the hard drive.
    • Remove the screws that secure the hard-drive assembly to the palm rest and keyboard assembly.
  2. Dell Inspiron 11-3162 Hard Drive Replacement, Slide and Lift the Hard-Drive: passo 2, imagem 1 %32 Dell Inspiron 11-3162 Hard Drive Replacement, Slide and Lift the Hard-Drive: passo 2, imagem 2 %32
    • Slide and lift the hard-drive assembly off the palm rest and keyboard assembly.
  3. Dell Inspiron 11-3162 Hard Drive Replacement, Remove the Screws: passo 3, imagem 1 %32
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  4. Dell Inspiron 11-3162 Hard Drive Replacement, Lifting the Hard Drive: passo 4, imagem 1 %32 Dell Inspiron 11-3162 Hard Drive Replacement, Lifting the Hard Drive: passo 4, imagem 2 %32
    • Lift the hard drive from the hard-drive bracket.
  5. Dell Inspiron 11-3162 Hard Drive Replacement, Align the Screw Holes: passo 5, imagem 1 %32
    • Align the screw holes on the hard drive with the screw holes on the hard-drive bracket.
  6. Dell Inspiron 11-3162 Hard Drive Replacement, Replace the Screws: passo 6, imagem 1 %32
    • Replace the screws that secure the hard-drive bracket to the hard drive.
  7. Dell Inspiron 11-3162 Hard Drive Replacement, Connecting the Hard Drive: passo 7, imagem 1 %32
    • Slide and connect the hard-drive assembly to the connector on the system board.
  8. Dell Inspiron 11-3162 Hard Drive Replacement, Align the Screw Holes: passo 8, imagem 1 %32
    • Align the screw holes on the hard-drive assembly with the screw holes on the palm rest and keyboard assembly
  9. Dell Inspiron 11-3162 Hard Drive Replacement, Replace the Screws: passo 9, imagem 1 %32
    • Replace the screws that secure the hard-drive assembly to the palm rest and keyboard assembly.
Conclusão
6 outras pessoas executaram este guia.
Terrence15
Membro desde: 12/18/17
79.161 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.986 guias
Um comentário
Can we replace the harddisk with SSD. Will that increase the performance of the laptop?
Winada Effendi - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 13
Últimos 30 dias: 34
Duração total: 6,005
