Ir para o conteúdo principal
Dell Inspiron 11-3152 Screen Replacement
O que você precisa
  1. Dell Inspiron 11-3152 Screen Replacement, Back Panel: passo 1, imagem 1 %32 Dell Inspiron 11-3152 Screen Replacement, Back Panel: passo 1, imagem 2 %32
    • Flip the computer over.
    Pergunte ao FixBot
  2. Dell Inspiron 11-3152 Screen Replacement: passo 2, imagem 1 %32 Dell Inspiron 11-3152 Screen Replacement: passo 2, imagem 2 %32
    • Remove all nine 5mm Phillips head screws from the back cover using #0 Phillips head.
    Pergunte ao FixBot
  3. Dell Inspiron 11-3152 Screen Replacement: passo 3, imagem 1 %32
    • Gently use a spudger to pull the cover away from the rest of the laptop. The cover will come off after you use the tool on two or three sides.
    Pergunte ao FixBot
  4. Dell Inspiron 11-3152 Screen Replacement, Battery: passo 4, imagem 1 %32
    • Make sure that the power is off.
    • After taking off the back panel, you will see the battery located at the bottom of the computer system. It's black and is clearly labeled "dell battery".
    Pergunte ao FixBot
  5. Dell Inspiron 11-3152 Screen Replacement: passo 5, imagem 1 %32 Dell Inspiron 11-3152 Screen Replacement: passo 5, imagem 2 %32
    • Locate the battery at the bottom of the computer and remove the four 3mm screws with a Phillips #0 head that hold the battery down.
    Pergunte ao FixBot
  6. Dell Inspiron 11-3152 Screen Replacement: passo 6, imagem 1 %32
    • Remove the Solid State Drive wire from the battery clip by detaching the wire.
    • This can be done by gently pulling the connector away from the battery clip.
    Pergunte ao FixBot
  7. Dell Inspiron 11-3152 Screen Replacement: passo 7, imagem 1 %32
    • Remove the battery from the computer system by gently lifting it from the side.
    Pergunte ao FixBot
  8. Dell Inspiron 11-3152 Screen Replacement, Screen: passo 8, imagem 1 %32
    • Unscrew the brackets in the top right and top left of the laptop. Unscrew the two 1mm screw from both of the brackets on both sides with #0 phillips head.
    Pergunte ao FixBot
  9. Dell Inspiron 11-3152 Screen Replacement: passo 9, imagem 1 %32
    • Disconnect the aerial cables from the wireless controller by pulling them away from the laptop.
    Pergunte ao FixBot
  10. Dell Inspiron 11-3152 Screen Replacement: passo 10, imagem 1 %32
    • Push the brackets up on both sides with your hands or spudger.
    Pergunte ao FixBot
  11. Dell Inspiron 11-3152 Screen Replacement: passo 11, imagem 1 %32 Dell Inspiron 11-3152 Screen Replacement: passo 11, imagem 2 %32
    • At this point you can pull the bottom half of the computer away from the screen.
    • The screen is now fully detached and ready to be replaced!
    Pergunte ao FixBot
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 42
Ao todo: 715
