Ir para o conteúdo principal
Dell Inspiron 11-3147 Wireless Card Replacement
O que você precisa
  1. Dell Inspiron 11-3147 Wireless Card Replacement, Wireless Card: passo 1, imagem 1 %32 Dell Inspiron 11-3147 Wireless Card Replacement, Wireless Card: passo 1, imagem 2 %32
    • Using a plastic Philips Head #1 Screw Driver, remove the nine 7mm screws holding the back cover in place.
    • The cover is held on with small plastic tabs. Starting from the back of the machine use your hands to gently prey the back cover from the machine and release these tabs. While a tool is not necessary a plastic spudgercan be used to lift the first few tabs.
  2. Dell Inspiron 11-3147 Wireless Card Replacement: passo 2, imagem 1 %32
    • Remove the single 3mm screw holding down the hardware using a plastic Philips Head #0 Screw Driver.
  3. Dell Inspiron 11-3147 Wireless Card Replacement: passo 3, imagem 1 %32
    • Detach the wires connected to the wireless card.
  4. Dell Inspiron 11-3147 Wireless Card Replacement: passo 4, imagem 1 %32
    • Ensure both wires are detached from the piece.
  5. Dell Inspiron 11-3147 Wireless Card Replacement: passo 5, imagem 1 %32
    • Lift the wireless card upwards and remove.
Conclusão
William Brum
Membro desde: 03/04/16
755 Reputação
Autoria de 5 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 33
Ao todo: 1,387
