Ir para o conteúdo principal
Dell Inspiron 11-3147 CMOS Battery Replacement
O que você precisa
  1. Dell Inspiron 11-3147 CMOS Battery Replacement, CMOS Battery: passo 1, imagem 1 %32 Dell Inspiron 11-3147 CMOS Battery Replacement, CMOS Battery: passo 1, imagem 2 %32
    • Using a plastic Philips Head #1 Screw Driver, remove the nine 7mm screws holding the back cover in place.
    • The cover is held on with small plastic tabs. Starting from the back of the machine use your hands to gently prey the back cover from the machine and release these tabs. While a tool is not necessary a plastic spudger can be used to lift the first few tabs.
  2. Dell Inspiron 11-3147 CMOS Battery Replacement: passo 2, imagem 1 %32
    • Using a plastic spudger, gently press under the battery to lift it up and out.
  3. Dell Inspiron 11-3147 CMOS Battery Replacement: passo 3, imagem 1 %32
    • Remove the CMOS Battery
Conclusão
William Brum
Membro desde: 03/04/16
737 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 3-1, Bhusal Spring 2016 Membro de UMass Dartmouth, Team 3-1, Bhusal Spring 2016
UMASSD-BHUSAL-S16S3G1
Membros da 3
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 37
Duração total: 3,052
