Ir para o conteúdo principal
Dell Inspiron 11-3138 Memory Modules Replacement
O que você precisa
  1. Dell Inspiron 11-3138 Memory Modules Replacement, Popping up the Memory Module: passo 1, imagem 1 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before Working Inside Your Computer" After working inside your computer, follow the instructions in "After Working Inside Your Computer".
    • Use your fingertips to carefully spread apart the securing-clips on each end of the memory-module connector until the memory module pops up.
  2. Dell Inspiron 11-3138 Memory Modules Replacement, Removing the Memory Module: passo 2, imagem 1 %32 Dell Inspiron 11-3138 Memory Modules Replacement, Removing the Memory Module: passo 2, imagem 2 %32
    • Remove the memory module from the memory-module connector.
  3. Dell Inspiron 11-3138 Memory Modules Replacement, Aligning the Notch: passo 3, imagem 1 %32
    • Align the notch on the NEW memory module with the tab on the memory-module connector.
  4. Dell Inspiron 11-3138 Memory Modules Replacement, Securing the Memory Module: passo 4, imagem 1 %32
    • Slide the memory module firmly into the connector at an angle and press the memory module down until it clicks into place.
    • NOTE: If you do not hear the click, remove the memory module and reinstall it.
Conclusão
Terrence15
Membro desde: 12/18/17
79.121 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.985 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 236
