Ir para o conteúdo principal
Dell Inspiron 11 i3147 Processor Fan and Heat Sink Replacement
O que você precisa
  1. Dell Inspiron 11 i3147 Processor Fan and Heat Sink Replacement, Processor Fan and Heat Sink: passo 1, imagem 1 %32
    • Close the computer and turn it over, with the bottom of the computer facing up.
  2. Dell Inspiron 11 i3147 Processor Fan and Heat Sink Replacement: passo 2, imagem 1 %32
    • Remove the nine 7.6mm PH0 screws on the cover.
  3. Dell Inspiron 11 i3147 Processor Fan and Heat Sink Replacement: passo 3, imagem 1 %32
    • Use a plastic opening tool to remove the cover from the computer.
  4. Dell Inspiron 11 i3147 Processor Fan and Heat Sink Replacement: passo 4, imagem 1 %32
    • Remove the three 4.7mm PH0 screws that secure the battery to the computer.
  5. Dell Inspiron 11 i3147 Processor Fan and Heat Sink Replacement: passo 5, imagem 1 %32
    • Remove the hard drive cable from the battery.
  6. Dell Inspiron 11 i3147 Processor Fan and Heat Sink Replacement: passo 6, imagem 1 %32
    • Lift the battery from the keyboard.
  7. Dell Inspiron 11 i3147 Processor Fan and Heat Sink Replacement: passo 7, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
  8. Dell Inspiron 11 i3147 Processor Fan and Heat Sink Replacement: passo 8, imagem 1 %32
    • Use a screwdriver to remove the two 2.3mm PH00 screws on the processor fan.
  9. Dell Inspiron 11 i3147 Processor Fan and Heat Sink Replacement: passo 9, imagem 1 %32
    • Use a PH0 screwdriver to loosen the 4 captured screws on the heat sink assembly.
  10. Dell Inspiron 11 i3147 Processor Fan and Heat Sink Replacement: passo 10, imagem 1 %32
    • Remove the processor fan and heat sink assembly.
Conclusão
Uma outra pessoa concluiu este guia.
Muhammad Erchid
Membro desde: 10/09/18
1.069 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S1-G6, Leahy Fall 2018 Membro de USF Tampa, Team S1-G6, Leahy Fall 2018
USFT-LEAHY-F18S1G6
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 279
