Ir para o conteúdo principal
Dell Inspiron 11 i3147 Power Buttons and Volume-Buttons Board Replacement
O que você precisa
  1. Dell Inspiron 11 i3147 Power Buttons and Volume-Buttons Board Replacement, Power Buttons and Volume-Buttons Board: passo 1, imagem 1 %32
    • Close the computer and turn it over so that the bottom of the computer is facing up.
  2. Dell Inspiron 11 i3147 Power Buttons and Volume-Buttons Board Replacement: passo 2, imagem 1 %32
    • Remove the nine 7.6mm PH0 screws on the back cover.
  3. Dell Inspiron 11 i3147 Power Buttons and Volume-Buttons Board Replacement: passo 3, imagem 1 %32
    • Use a plastic opening tool to remove the cover from the back of the computer.
  4. Dell Inspiron 11 i3147 Power Buttons and Volume-Buttons Board Replacement: passo 4, imagem 1 %32
    • Remove the three small 4.7mm PH0 screws that secure the battery.
  5. Dell Inspiron 11 i3147 Power Buttons and Volume-Buttons Board Replacement: passo 5, imagem 1 %32
    • Move the hard drive cable away from the battery.
    • You want to make enough clearance to remove the battery without it catching on the hard drive cable.
  6. Dell Inspiron 11 i3147 Power Buttons and Volume-Buttons Board Replacement: passo 6, imagem 1 %32
    • Lift the battery up and toward yourself to remove it, revealing the back of the keyboard underneath.
  7. Dell Inspiron 11 i3147 Power Buttons and Volume-Buttons Board Replacement: passo 7, imagem 1 %32
    • Disconnect the cable for the power and volume buttons from the motherboard.
    • You may need to use a spudger to remove the cable from the routing guides by the speaker.
Conclusão
Muhammad Erchid
Membro desde: 10/09/18
1.051 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S1-G6, Leahy Fall 2018 Membro de USF Tampa, Team S1-G6, Leahy Fall 2018
USFT-LEAHY-F18S1G6
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 363
